DanielW
- Location
- Haliburton, Ontario
Interesting point. And to be sure, prices for running gears alone seem to be steadily increasing here too. A good trick is to look for forage wagons. No one wants to deal with old rotted out forage wagons, and often times the running gear is decent. You can often get old forage wagons with rotted wood and decent running gears for peanuts. Push the box off and into the burn pile with the backhoe and set fire to it, use the running gear to build a new hay wagon, and once the fire's done take all the steel from the forage box to the scrappers (the money you get back will pretty much cover the original cost of the wagon).You'd probably make more money loading those running gears up and shipping them to Western New York. Even the junkiest seized up running gear goes for $300-400 at auctions around here. Decent ones with tires that hold air bring several hundred dollars.
Tires have never been much of an issue for me: A scrapyard up the road always has a great selection of used truck tires in good shape for $10 a piece, and I have all the tooling to swap tires around and throw new tubes in.
