Town Piddler
Greetings from Colorado. I bought an old New idea 400 hay rake. We got everything working except it needs new tine bearings for the five bars. There is another YT post that talks about possible sources of the bearings but it never actually states who has these bearings. Many people gave ideas about people to call and websites to check. None of these worked out from my web search and as far as I can tell from the posts. Shoup has a similar bearing for a New Idea 402 and up, but i bought one and it has a smaller outer diameter. There are a couple of overseas websites that list the part but the websites do not appear to work.
Pressing the bearing off does not work, because the top of the bolt assembly is rounded over the bearing and would have to be ground off. In other words, the shaft would be rendered useless. We wanted to check with the YT Community before we tried to find a stand-alone bearing into which we could press a bolt and then place a collar on the bolt. FYI, I pressed the bearing off after grinding off the top, and the bolt and threaded rod/bolt are machined as one piece.
I am hoping there is someone out there with a tried and true NI 400 who has found a definite source for this part.
Brand- New Idea
Model- 400
Part #-OEM 618 MEA
Part # on bearing- 6586 BCA
Thanks in advance for your help.
Brand- New Idea
Model- 400
Part #-OEM 618 MEA
