jjj_85
- Location
- Central Iowa
I recently acquired a 1945 2N tractor with a 49 8N engine. The engine was stuck when I got it home but I was able to oil the cylinders with ATF overnight and it popped free dragging it on the trailer with the winch. After sitting a few more days I was getting 110 110 80 and 110 compression wet. I believe there is a bit of a ring ridge on number 3 but the more I crank it the better it gets. There is little to no gallop when cranking now. Dry they are around 90 psi. Was hoping they'd all come around after some heat cycles but I cannot seem to get it running. The old battery was dated 2012 but I have no idea if the last owner had it running. I have removed the distributor and replaced the points, condenser, cap, and rotor. I replaced the wires and verified the 1243 firing order. Not the tractor has what I believe is a strong spark. I replaced the carb and it currently has a 1 gallon temp fuel system. The air cleaner is not connected to the carb since the boots turned to dust. The distributor will actually seat both ways and I believe at some point someone had it in backwards. I installed it aimed at the number 1 wire with number 1 cylinder at the top of compression stroke. I even set the timing with a DVOM when I had the distributor off. I disconnected the exhaust at the manifold incase the muffler was plugged. At this point I believe I have decent compression, spark, and fuel. I disconnected the oil line from the gauge and verified it is moving a decent amount of oil. Coolant was drained but all other fluids are full and look fine. It will occasionally backfire from the carb and it smokes a little from the exhaust but it wont even try to fire. I'd love to put some money into this thing and bring it back to working condition but I really want to hear it run first. I am at a loss here. Never ran into something I couldn't figure out like this and was hoping someone might have some input here.
