You all helped me a year ago, need additional help. Old story, transmission would not stay in 5th gear without a bungee on the shifter. Several people offered up help and guidance. I ended up splitting tractor and replacing the 4th/5th sliding gear, inside of old slider pretty well worn out from pulling into gear while moving (I suspect). The gear that 4/5 meshes with to make 5th appeared worn but I hoped that since the 4/5 slider was so worn that it would be ok. Not so. Tractor ride last June, shifter will not stay in 5th. Keeps sliding out of 5th. A bungee will hold it in gear no problems. I am delving into this tractor again. I am going to look hard at the shift rail as it seems very easy to move the shifter up out of 5th gear, and of course the meshing gear to achieve road gear. Can any one give me a part number for that gear? I must confess since this tractor belongs to someone else, I never bought a manual. May need to yet. Any and all help is appreciated. thanks in advance gobble
