TEA 2085 Replacing PTO oil seal bearing instructions
RonON
I have a leak from the rear of the PTO on my 1952 Ferguson TEA 20 (SN TEA 244026) and am going to replace the oil seal and possibly the bearing if needed. However, I don't have instructions for this job. Can anyone who has a workshop for the TEA 20 scan and post the instructions for this job as a reply to this post. Alternatively, any in depth instruction regardin how to remove the old seal and replace it with a new one as well as the bearing replacement would work. I think that it is straight forward but want to make sure that I am doing it correctly. Thanks in advance for any help provided!
Ron
No worries, I have changed the seal, bearing and sleeve on the PTO shaft without incidence or leaks. No need to answer to provide instruction from the workshop manual. I guess no one has one?
Ron
(quoted from post at 07:37:53 07/22/23) No worries, I have changed the seal, bearing and sleeve on the PTO shaft without incidence or leaks. No need to answer to provide instruction from the workshop manual. I guess no one has one?
Ron
Ron, I saw your post but didn't actually read it because the subject said TEA 2085 and I thought that I wouldn't know anything about that tractor.
Happy to see that you got fixed.
Ron (Ont),
The email address that you supplied did not work. Is the spelling supplied correct, with spaces, caps, lower case letters etc. If you can supply the correct address I'll email you for information.
Thanks,
Ron
(quoted from post at 14:54:56 07/30/23) Ron (Ont),
Thanks,
Ron
You need to replace the AT with the @ sign, no spaces. The site does not always like email addresses in the text.
(quoted from post at 15:47:17 07/30/23)
Thanks,
Ron
Try posting your email address.
