Mountain_anderson
Hi all
I have a Tecumseh hh60 with the internal coil on a Troy bilt horse. It would start and idle fine but lose power when put under load, just putting it into gear it, would move about 6inches and would cut the engine. I noticed it had a bad spark so I replaced the plug. Tested it and the plug still had the weak spark, removed engine face, gas tank, and fly wheel to potentially clean the points. Cleaned them and set them to the proper gap. I reassembled and now it won’t start at all, plus it’s hard to pull. No start, hard cranking, and no spark as well. Not sure if I did somethinf to affect the timing? How could I fix this?
