I have a 1600sf detached block garage on my property, which i purchased not long ago. I had a new shingle roof put on it right off the bat. They had to replace most of the decking. They said many were termite damaged but so no actual live termites. The trusses are exposed on the inside (no ceiling / attic). This is in Florida. There are no active termites anywhere that i've seen or seen evidence of (wings frass etc). The building is 50+ years old so likely damaged at points in the past.
The trusses all appear, to the eye, fine. However once i started inspecting / touching them, many are somewhat brittle to the touch. Not that they'll disintegrate in your hand, but noticeably soft.
So, i've coated all the trusses and decking (from the inside) with boracare (to prevent future termites) which i've used at other points in time in other locations with good success. I'm going to be converting this detached block garage essentially into a guest house.
My question is in regards to wood hardeners. I've read that penetrating epoxy hardeners & similar products can solidify the existing wood. I've seen some things such as Abatron Liquidwood, Minwax Wood Hardener and some others. It seems I'd need many thousands of dollars worth of these products to coat the trusses. Any other alternatives here? I've seen an outfit or two selling generic penetrating epoxy (not for any specific purpose). Is sistering into such wood as it is viable? Thanks!
