will-max dairy
We bought our Mahindra 6075 about five years ago now... and I always knew that it had a geared PTO feature. There is a lever on the left side to the rear of the seat that shifts the PTO between "Normal", which is 540PTO RPM at 2000 engine RPM and "Economy", which is 540PTO RPM at 1500 engine RPM.
According to the manual, this is to save fuel when running "easy" implements.
Well, I never thought that a baler was "easy"...so I have run the Normal setting all of these years.
The other day, I was running our 7 foot haybine with the tractor, and I needed to slow down for some thick, down, tangled and heavy hay...like 2-3 ton per acre late July hay with dead first growth blown down by a recent storm into the clover and trefoil undergrowth... It was annoying to be driving 3mph while the engine was screaming at 2000 RPM to run the haybine. So... I tried the economy setting... what a difference... it made slow, frustrating mowing bearable.
So... when we baled that hay, I experimented with that setting on the baler. After all, the baler is all about the flywheel... if you have the flywheel up to speed, it's not working your tractor's PTO hard... right?
It ran the baler just fine for the load that I baled first, with my grandson riding... and we could talk while the baler was running... which is key with a four year old riding while baling... you are baling 3-6 bales per minute; while fielding 4-10 questions per minute... "Papa, why did that bale miss the wagon?..." lol
For the bulk of the baling that day, I set up my wife and father-in-law with instructions on running with the Economy setting.
They both reported that it was a much better experience... the tractor just hummed along all day long; while they talked and strategized of which windrow to bale next, etc.
I did hear a little "chatter" from the PTO transmission at times, but I hear that on the Normal setting as well... and I suspect that it's going to be easier to hear it over the engine, when the engine isn't so loud.
