Tractor Weights for 28" 6 Loop Rims
Lynn Patrick
Full set of Roloff wheel weights (6) with all necessary hardware (mounting wedges, bolts, washers & burrs) for your 6 loop 28” rear rims. 3 pieces per wheel and 75 lbs per weight means an additional 225 lbs per tire. Made by Roloff to fit inside between the tire rim and fender puts the weight right where it needs to be! $350 Call West Branch, Three19-643-363Zero
I put a set of these on my 53' NAA when I changed the tires the last time, and I really like the idea of dry wheels and tubes, rather than fluid. Worked great.
