Trailer torque specs
Have built many trailers. Always used gussets on the hangers and always installed the bolts with the nut on outside. Makes it easy to check that nut is not backing off by looking from outside. Do not have to crawl under to check. On heavier trailers have slid a plate down the outside of frame and hanger to add strength. .
That’s what I did. As far as I know all the hardware was original, had to torch it off. The bolt heads were on the outside, I put the new ones in from behind. Going to be replacing everything but the axles. This was an emergency repair, one of the springs broke.
