Hello all,
Hopefully my having a couple of tractors will warrant me some forgiveness for a non-tractor question. Nobody seems to know more tricks than tractor guys, so I come with hat in hand.
I'm trying to remove a CV joint tripod that is on a splined axle. I got the joint on one side off as easily as expected with a slide hammer. Passenger side joint is another story. Slide hammer didn't budge it. No problem, I thought, I'll get my puller. That thing with my heavy duty impact driver wouldn't budge it either. The retainer ring was removed intact. I've cleaned the ring groove and see no burrs or anything else.
I think the puller will break if I put much more into it. I've never had the puller not work. I've got it soaking in kroil and will let it sit overnight and try again. Maybe I'll get lucky with that. With the bearings, I'd think heat was out of the question. Then again, maybe not IF there are no seals in the bearings.... but I don't know if there are or not.
Any suggestions? Thanks again, and apologies if due.
