wore out
You are most welcome!Hi scootergmc and all, everybody loves a mystery novel, and it is because not all the facts are known right away. It is the journey that is of interest. Don't let this stop you from getting involved, look at it as entertainment.
I am confident that I have found the solution, although it will take me days to be sure. I do not want to waste any more of your time and I apologize for the time I have wasted . The solution appears to be the air cleaner.
When I bought the tractor it ran well. There was no reason to suspect anything. It started having problems after it sat here for a while. But then, life is like that: things go well until they don't, then go bad suddenly, sometimes very bad. The air cleaner waited for me to get the tractor before it clogged up enough to cause problems. When I saw the fuel, I took it to be flooding, since the carb had never been touched, and it had over 60 years to wear on the float valve.
I should have noticed it right away. I blame it on having been raised in the city. I never worked on large machinery and in particular on anything with this kind of air filtration, except for a very old lawn mower, or two. Truth is, it has not been cleaned in many years, and the pre-cleaner was almost plugged. I'm sure I saw it at some point too, probably thinking the pre-cleaner was oiled foam instead of the hardware cloth it really is. That is what it looked like. The poor engine was just doing it's best as long as it could. It is a reminder to do regular maintenance. The previous owners didn't. I should have known that too, since they added water to the antifreeze when the radiator leaked. Who would do that in this part of the country?
Again, thanks to all of you for your time and consideration.
And thanks for posting back with what seems to be the solution.
So many come here with problems and members spend a lot of time trying to help them, and then the O.P. disappears and we never know if their problem was ever solved.
If something changes or another problem crops up please come back and let us know about it, there's MANY here willing to help
