ridgeandvalley
Had an 8n for many years. With that tractor I could "feather the clutch" if that's the right term so that starts were smooth as could be. If I was hooking up an implement, I could easily creep the tractor forward or backwards just the right amount to line things up.
In 2018 I picked up a Ford 960 since I needed some more horsepower to run a haybine and baler. It has the live PTO and the 2 stage clutch. I found myself making "lurching" starts rather than smooth ones. I figured as I got used to the new tractor, I'd get the feel for it. Still doesn't feel as smooth as I'd like. It feels like the clutch doesn't engage until it reaches the very top end of its travel and then engages very quickly. I do throttle down and that helps some, although I really didn't have to do that with the old 8n.
I don't know if I'm describing this well, but is it just the nature of the 2 stage clutch and the higher angle at the top position of the pedal, or is there an easy adjustment that I should be looking at. I know I can move the pin to make it a single stage, but I don't really want to give up the live PTO by doing that. I'd love to be able to more gradually engage the clutch for those smooth starts and tiny little movements necessary for hooking up implements.
