I got the great idea to adjust the valves on my 350, this would be the same engine as many green JDs have (1020 IIRC)
The front two valves adjusters do not have any interference fit to the threads so I got the great idea to try and "stake" them in place, but now I see the front rocker can slide over on the shaft, there is not enough shaft to have a cir-clip on the end but I see in the parts manual there is a "plug" the rear seems to have one but the front does not and the parts manual calls for 2.
The thing is I cannot locate the one that I may have knocked out and just want to confirm that there must be on on each end, also what is the cure for the "loose" valve adjustment ???
BTW it was a good idea those front rockers were very loose, like over .045
The thing is now in my service bay which I need to clear.
