DanielW
- Location
- Haliburton, Ontario
Hi folks,
I'm looking for some info on the bale restrictors that were optional with older Vermeer balers. I know Hay DR and KEH have posted a few times about them, so
I'm hoping one or both of them might see this and be able to help.
I recently bought a 504G, knowing that these can work with lower HP tractors if the drive sprockets are swapped around and the bale restrictors are in place. I
work at a machine/fabrication shop, so making the new 11 tooth sprockets was easy. I suspect the bale restrictors will also be fairly straight forward to
fab/form, but I have no idea what they are, what their proper function is, or where they go - only that they help reduce required HP and make nicer-looking
bales. I plan to run with a Case 630 (48 PTO HP - rebuilt engine 4 years ago), which I understand should be plenty for one of these balers with the smaller
drive sprocket and bale restrictors as long as I don't mind going slower to match the slowed-down baler.
Any input on this would be greatly appreciated (pictures or diagrams would be fantastic). I ordered a parts manual, but just found out it won't arrive for
another 3 weeks at least, and even when I get it I'm not sure it will have the info I'm looking for.
Thanks kindly,
Dan
Thanks kindly,
Dan
