Yesterday I took off the shifter cover and put a new gasket on it. I didn’t think there was one on it, it appeared to be leaking around the cover but I’m pretty sure now the oil was migrating from the leaking steering arm seals. Oh yeah, be careful when removing this cover, there is a detent spring and ball under the rear center of the cover for one of the shift rails. If you do remove them. Place them in a magnetic parts dish. If you don’t have one, go get one. They are great. I will remove the steering box and take it apart when I get the engine off. Tractor had a heavy hanger strap anchored to the RH hydraulic inspection cover that went around the muffler. The strap is bent and I couldn’t tighten it so I installed a new one that bolts to one of the axle trumpet studs and holds the exhaust pipe instead of the muffin. A new muffin and tailpipe assembly will be installed during overhaul and possibly a new manifold, the exhaust flange on the old one don’t look so good.
