Where do the three wires on an Allis Chalmers G tractor go to?
Here is a copy of the switch picture you posted to your Profile Posts. Hope this helps.
Thank you for this diagram. It helped a lot now I need to know where the plug wires go to the distributor.
Going from memory here so I could be mistaken. With #1 at TDC on the compression stroke the rotor should be pointing to the #1 spark plug. OP manual should explain it.
Is the distributor in the engine or do you need to install it first? I ask as it is possible that the wires may need to be in some other location than is shown in a picture or drawing, if the distributor was not installed in the right location. You may need to locate where the #1 wire goes by finding TDC of the compression stroke of #1 cylinder.
I sent you some info in a conversation, check the envelope up top next to your username.
Edit to add: I sent you a copy of the old Allis Chalmers G Manual.
Jona here is some info from the manual on the distributor. Hope it helps. Sorry about the small print.
[ATTACH =full]80931[/ATTACH]
I think we are neighbors have been Holman, but I still don’t have things right JOna
