Hi folks,
We've had a problem with our 2-105 for a few years now, where the hydraulic flow from the remotes is (very) significantly reduced if you happen to be operating the brakes while using the remotes. It's rather irksome, as we use this tractor for round baling, and most of our fields are on hills; You almost always want to instinctively be braking while you open the gate, but if you do so the gate will shudder and open very, very slowly from lack of flow.
Because we now only do about 120 round bales a year, it hasn't been at the top of my priority list to fix. But it's getting to the point where I'd like to look at it soon. I suspect a bypass/leaking piston in the brake valve. Looking at the AGCO parts books, it looks like the seals on the brake pistons are just SAE #119 O-rings (with #112 O-Rings for the spool where it exits the valve body and a gasket for the end cap). I'm thus hoping it's pretty easy to re-seal these, and I'm not surprised that this would be an issue, since I had to re-seal the compensator and priority valve spools last year.
But I thought I'd ask here first in case anyone has any other thoughts/advice. I also confess that I haven't looked into how easy/hard a job it is to access/remove the brake valve, so any advice on that is greatly appreciated. We've only had this tractor for about 5 years, and because it only gets used a few hours each year (and because I confess we all hate using this tractor) I really don't pay much attention to it and haven't learned its mechanical 'ins and outs' like I have any of our other tractors.
Any thoughts/advice greatly appreciated.
Daniel
Daniel
