I have a 1955 VAI Case that I am having some carb problems with. I have cleaned and rebuilt the carb, fuel tank was chemical cleaned and lined. The only way I can keep the tractor running is to have the choke closed to the 3/4 position. It does however, run pretty smooth this way.
I have tried adjusting the carb but no matter what I do, the choke has to be partially closed in order to run.
After the carb rebuild, I had removed the inline fuel filter as suggested by a tractor mechanic friend of mine, so filter is not the problem. (He had suggested that the inline fuel filter might have been the source of my original problems before the rebuild. His position was that naturally aspirated carbs sometimes do not have enough vacuum to pull adequate fuel. I was a little sceptical at the time (still am) but tried it anyway)
Any advice would be much appreciated. (I also have other issues to address but one thing at a time).
