Thanks to everyone who offered advice. I did a lot of checks based on your suggestions and learned a lot through it all. (I could probably take the carb apart and put it back together blind-folded now)
I think I finally found the problem. The last time I removed the carb, I noticed there was very little fuel in the bowl. I thought the float was properly adjusted, but now think it was not. I adjusted the float to raise the level and it seems to be running much better now. ( The old girl even looks a little happier now.)
Gave the carb a good dose of brakeclean while it was running. No indication of air leakage but the carb is a lot cleaner now!
Checked the float, I initially thought it was adjusted right, but adjusted it to raise the level in the bowl a bit and now it's running much better. Thanks for suggesting the check.
