wore out
I agree.So what explains the first use of ether?
If the rings aren't broken, you won't have to use ether. If you never use ether, the rings won't be broken from using ether. If the rings aren't broken from using ether, you'll never have to use ether. You think maybe someone just woke up and said, "Let's spray some ether in this perfectly good engine for no reason whatsoever, and break the rings?"
Fun fact, engines don't run long with broken rings.
Seems like despite how many times people PROVE that there is no such thing as "addiction to ether" and that "ether destroys engines" is a lie, those myths will never die.
I don't think the occasional use of ether is likely to break rings UNTIL the rings, grooves and piston/cylinder wall clearances are worn after many hours of engine use and the rings get slammed about.
