Will CA Rockshaft fit on a B
ShepFL
I have a 1939 B (no electrics other than magneto with gee and haw hand brakes). Recently bought a lift plow for it. I have all the parts but depth lever (in work) and rock shaft that mounts behind seat.
Seen one on ebay and was wondering if it would fit the B.
You can make about anything work if you have a welder and a saw. The big problem with using the CA rockshaft assembly is the cylinders and the oil flow volume. I am thinking of doing the same thing but will put the CA transmission and hydraulic pump in the B. You would need a pan seat to clear the CA hydraulic pump. I might use the C instead of the B but still need the seat raised more than normal or the pan seat. I have all the junk needed just been thinking about it.
