Yanmar 2310D Wont Move
JHughes-HT
I have a 2310D that I use to plow snow, I was plowing in reverse with the range gear in 3rd and I moved the power shift into neutral position then into 1st and it didn't shift into gear. No noise made just didn't move, doesn't matter what gear is selected it won't do anything. The PTO also won't engage. I thought maybe the fluid was low so I checked and it was slightly low so I added fluid and still nothing. Towed into my garage and can't see to find anything wrong, any suggestions?
Sounds like clutch went out or drive spline collar at end of clutch shaft. Have you made certain your range shift is engaged?
