Yanmar YM1510D Need to move it with no power (Tow it)
TFreeman-HT
Do I need to disengage the hydro drive before pulling with another tractor. Unit will not start and is in gear.
If so, where is the bypass?
I am not sure but would suppose if you taake the power shift out of gear as well as the range shift, then lock the clutch down and I think it might pull. Although I have worked on a couple of power shifts I am not sure about what I just said. If it seems to free wheel I am pretty sure you would be ok.
Upvote 0
Thanks. That is what I was thinking.
Upvote 0
You got it right. I've done this a few times.
Clutch pedal off, a little more effort to move it.
Clutch pedal on, a bit easier to move it.
Also disengage the PTO. (y)
Upvote 0
