Home |Gallery |Forum |Ads Sponsored by Yesterday's Tractors
Yesterday's TrucksThe Classic Truck Resource Page
Vintage Truck Headquarters
Featured Photo
Click to View
Features
Discussion Forum
Forum Archives
Truck Photos
Model Profiles
Truck Links
The Market
Picture List
Contact Us
Antique Tractors
Kountry Life
Tractor Manuals
[Home]
This is the modern view of the Yesterday's Trucks Forum. Just login with your YT Userid and password to post. If you have trouble logging in, contact us by email to support at ytmag.com, or through the Reader Form, and we will get you going right away.
Click here to return to Yesterday's Tractors Forum Index
'54 Dodge Y w/ Timkin Rear Axle
Post new topic    Yesterday's Trucks Forum Index -> Yesterday's Trucks
John Saeli
PostPosted: Fri Aug 03, 2018 5:22 am    Post subject: '54 Dodge Y w/ Timkin Rear Axle Reply to specific post Reply with quote
Trying to locate a rear wheel seal for the ol"e Dodge. Axle is Timkin (deep) (double) reduction, 2 speed. Not sure what terminology is correct. Air brakes. Seal presses on the housing, has a hard rubber strip on the OD facing the hub. The hub has a grooved area that seats against the seal. Seal is 4-3/4" ID X 6-3/8" OD. Victor #
A2-1205-V-542. Cannot locate one anywhere. Any ideas?
Duner Wi
PostPosted: Fri Aug 03, 2018 6:52 am    Post subject: Re: '54 Dodge Y w/ Timkin Rear Axle Reply to specific post Reply with quote
See if that Victor # crosses to Stemco 309-0973. if it does Amazon says they have them.
John Saeli
PostPosted: Fri Aug 03, 2018 5:18 pm    Post subject: Re: '54 Dodge Y w/ Timkin Rear Axle Reply to specific post Reply with quote
Duner: Thanks for the reply. I gave our seal supplier the number you supplied & he has 1. The Stemco seal is 2 piece. With it all together, the bore is too small, but with the inner piece removed, it sounds like it will work. He is sending it, so we will see. Thanks again.
Duner Wi
PostPosted: Sun Aug 05, 2018 1:32 pm    Post subject: Re: '54 Dodge Y w/ Timkin Rear Axle Reply to specific post Reply with quote
John, If the seal supplied is incorrect there are more options. Do a search for your Victor # with out the dashes. You will probably end up with a Rockwell # that in turn crosses to a National # 5473 with cone 726 or 758. Some how or another this is more difficult than it should be.
John Saeli
PostPosted: Sat Aug 11, 2018 10:56 am    Post subject: Re: '54 Dodge Y w/ Timkin Rear Axle Reply to specific post Reply with quote
Duner: Got the seal and will work with the steel, inner piece removed, because the ID of the steel piece is too small. With the inner piece removed, the iD of the seal is like any other seal & will seal on the axle housing, except that the old seal also was steel on the ID and pressed on the axle housing, but was a larger ID. This seal also has the rubber outer ring that seals against the hub, and that dimension is OK, so all is well. Thanks again.
Duner Wi
PostPosted: Sat Aug 11, 2018 2:50 pm    Post subject: Re: '54 Dodge Y w/ Timkin Rear Axle Reply to specific post Reply with quote
I am glad you got it to work and thank you for the update.
Post new topic    Yesterday's Trucks Forum Index -> Yesterday's Trucks All times are GMT - 8 Hours
[Home]
Copyright © 2002-2013 YesterdaysTruck.com
Antique Truck Headquarters
