Home |Gallery |Forum |Ads Sponsored by Yesterday's Tractors
Yesterday's TrucksThe Classic Truck Resource Page
Vintage Truck Headquarters
Featured Photo
Click to View
Features
Discussion Forum
Forum Archives
Truck Photos
Model Profiles
Truck Links
The Market
Picture List
Contact Us
Antique Tractors
Kountry Life
Tractor Manuals
[Home]
This is the modern view of the Yesterday's Trucks Forum. Just login with your YT Userid and password to post. If you have trouble logging in, contact us by email to support at ytmag.com, or through the Reader Form, and we will get you going right away.
Click here to return to Yesterday's Tractors Forum Index
70's GMC 6500 SINGLE AXLE DUMP TRUCK
Post new topic    Yesterday's Trucks Forum Index -> Yesterday's Trucks
Cariboo4x4
PostPosted: Sun Jan 20, 2019 10:37 am    Post subject: 70's GMC 6500 SINGLE AXLE DUMP TRUCK Reply to specific post Reply with quote
I AM WORKING ON RETRACTING THE REAR SHOES ON THIS AXLE. There is two oval holes on backing plate and it appears there is a risty star wheel in each hole. Later today I will use the oxy-acet torch to heat up the "barrel" next to each star wheel. I expect its the brake shoe design with two wheel cylinders per backing plate. I can't find any photos or diagrams on internet nor do I have a service manual. It appears on one side of backing plate star wheel is located in top of oval hole and on bottom of ovaql hole on other side of axle. What I see next to star wheel I am hoping is the barrel that the star wheel threads into. Can anyone give me any photos, diagrams, or suggestions? Thank you. I am having a problem attaching photos to this post
Cariboo4x4
PostPosted: Sun Jan 20, 2019 10:40 am    Post subject: Re: 70's GMC 6500 SINGLE AXLE DUMP TRUCK Reply to specific post Reply with quote
Cariboo4x4
PostPosted: Sun Jan 20, 2019 10:42 am    Post subject: Re: 70's GMC 6500 SINGLE AXLE DUMP TRUCK Reply to specific post Reply with quote
The first two photos showing the oval holes, The photos came in sideways. The oval holes are located on either side of axle and are perpendicular to shop floor.
Cariboo4x4
PostPosted: Mon Jan 21, 2019 8:22 am    Post subject: Re: 70's GMC 6500 SINGLE AXLE DUMP TRUCK Reply to specific post Reply with quote
Yesterday we managed to pry drum off. I then figured out how to retract shoes next time. There appears to be a 5/16" or 3/8" cap screw holding a little bar against star wheel. With the drum on a person would rotate the drum so you could stick a long nut driver through one of the three holes that 3 countersunk bolts hold drum to axle. Once cap screws are loosened a person could rotate star wheel from back side of backing plate. Both little bars are perpendicular to shop floor.
One photo came in rotated. I'll post more photos later.
Cariboo4x4
PostPosted: Mon Jan 21, 2019 1:34 pm    Post subject: Re: 70's GMC 6500 SINGLE AXLE DUMP TRUCK Reply to specific post Reply with quote
Photo with hole that nut driver can go through to loosen little bar so star wheel can be turned. I discovered today the star wheel mechanism is seized.
I am trying to remove the star wheel mechanism assembly. So far the assembly will rotate back and forth on the backing plate. I can't seem to remove it. Pin in center turns with assembly and on back of backing plate is what appears a rivet head versus a bolt head.
Post new topic    Yesterday's Trucks Forum Index -> Yesterday's Trucks All times are GMT - 8 Hours
[Home]
Copyright © 2002-2013 YesterdaysTruck.com
Antique Truck Headquarters
