Home |Gallery |Forum |Ads Today's Tractors
Today's TractorsThe Modern Tractor Resource Page
Featured Photo
Click to View
The Market
Tractor Manuals
Tractor Shop
Features
Discussion Forum
Archives
Combine Photos
Information
Model Profiles
Safety Issues
Manufacturers
Reading Room
Contact Us
Antique Tractors
Classic Trucks
Kountry Life
YT Forums
Discount Parts
[Home]
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
This is the modern view of the Today's Tractors Forum. Just login with your YT Userid and password to post. If you have trouble logging in, contact us by email to support at ytmag.com, or through the Reader Form, and we will get you going right away.
Click here to return to Yesterday's Tractors Forum Index
Ford 4000 rear axle oil level plug not there?
Post new topic    Today's Tractors Forum Index -> Ford
swilk
PostPosted: Fri Jul 30, 2010 11:00 am    Post subject: Ford 4000 rear axle oil level plug not there? Reply to specific post Reply with quote
1965 Ford 4000. The book says its there ..... the NH web site diagram says its there .... but it aint there.
The area I think it should be doesnt have a plug .... it is either an untapped hole or has a press in plug in it.
Ideas? Am I looking in the wrong place.
swilk
PostPosted: Fri Jul 30, 2010 11:06 am    Post subject: Re: Ford 4000 rear axle oil level plug not there? Reply to specific post Reply with quote
According to the book the oil level plug should be where the pink dot is .... but there is no plug there.
The red dot has a bolt in it but according to the NH web site it is a screw with a nut on the back side for the hyd lift.
woodbutcher
PostPosted: Fri Jul 30, 2010 11:42 am    Post subject: Re: Ford 4000 rear axle oil level plug not there? Reply to specific post Reply with quote
My 4000 has a square shouldered plug in the plate that bolts onto the right side inboard of the footplate. The plug is hard to turn because it is on the same level as the footplate, and there's less than an inch of space to maneuver it. I think I can see yours in the bottom right corner of the second photo.
Butch
swilk
PostPosted: Fri Jul 30, 2010 12:04 pm    Post subject: Re: Ford 4000 rear axle oil level plug not there? Reply to specific post Reply with quote
This one? I will need to go and have a nut welded to it to get it out if so .... it is in there pretty good.
CliffP
PostPosted: Fri Jul 30, 2010 12:49 pm    Post subject: Re: Ford 4000 rear axle oil level plug not there? Reply to specific post Reply with quote
My manual shows this, if I can get this to work.
RodinNS
PostPosted: Fri Jul 30, 2010 1:39 pm    Post subject: Re: Ford 4000 rear axle oil level plug not there? Reply to specific post Reply with quote
Square headed plug in the bottom pic. Put a good Vise-Grip on it and turn it out.
Rod
swilk
All right then .... looks like the mangled, stuck plug is the one.
Hopefully a nut welded to it will be enough to get it out.
Thanks.
RickB
PostPosted: Fri Jul 30, 2010 2:20 pm    Post subject: Re: Ford 4000 rear axle oil level plug not there? Reply to specific post Reply with quote
Level plug on a 4000 is in the pump housing. Rod has it identified.
swilk
PostPosted: Fri Jul 30, 2010 2:58 pm    Post subject: Re: Ford 4000 rear axle oil level plug not there? Reply to specific post Reply with quote
Got it.
Took off the foot plate so that I could get a better grip on it .... finally came out.
Thanks.
RickB
PostPosted: Fri Jul 30, 2010 3:32 pm    Post subject: Re: Ford 4000 rear axle oil level plug not there? Reply to specific post Reply with quote
Be advised that the hole is supposed to be a 3/8-24 straight (machine) thread. THe photo loks like someone stuffed a 1/8" NPT zerk in it.
swilk
PostPosted: Fri Jul 30, 2010 4:22 pm    Post subject: Re: Ford 4000 rear axle oil level plug not there? Reply to specific post Reply with quote
Yes, yes they did.
I loosely put the same plug back in it for now but will run a tap through it when I have a chance and put the correct bolt back in it.
When I topped it off I noticed that I have a seal leaking around the brake rod. A little searching on this site turned up the correct R&R procedure ..... looks like it wont be that bad with the exception of fighting through years of paint on the threads to remove the brake hardware.
I am making a list of "to do" items ...... need to get the boots for the shifter rods. Both the tranny fluid and rear hyd fluid are a little milky and need to be changed out.
sotxbill
PostPosted: Sat Jul 31, 2010 7:41 am    Post subject: Re: Ford 4000 rear axle oil level plug not there? Reply to specific post Reply with quote
when you get it out,, buy a new pipe plug,, paint it yellow. Paint your dip stick yellow, paint your tranny check plug and oil drain plugs yellow. I do all my tractors so when it time to do maintainance,I can quickly find all the plugs and checks and dipsticks... even the radiator cap gets painted yellow...
helps when you drop them in the grass..
gas caps get painted red,,diesel caps green...radiators again yellow with all the other check engine crap... like the new cars... its easier for the wife to figure out..
I also paint the nozzles on the bulk tanks so she can get the right fuel in the right place...
but it doesnt work so well when she runs the diesels dry..
Post new topic    Today's Tractors Forum Index -> Ford All times are GMT - 8 Hours
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
Advertisement
Repair/Service manuals available for Allis, Ford, Farmall, John Deere and most other makes and models of tractors. If you are expecting to make repairs to your tractor, check our large online catalog of manuals. We probably have just what you need! Current Special - FREE book offer.    [Click here to visit this Sponsor]
Home | Manuals | Parts
Reproduction of any part of this website, including design and
content, without written permission is strictly prohibited.
Copyright © 1997-2013 TodaysTractors.com
Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others.
