Home |Gallery |Forum |Ads Today's Tractors
Today's TractorsThe Modern Tractor Resource Page
Featured Photo
Click to View
The Market
Tractor Manuals
Tractor Shop
Features
Discussion Forum
Archives
Combine Photos
Information
Model Profiles
Safety Issues
Manufacturers
Reading Room
Contact Us
Antique Tractors
Classic Trucks
Kountry Life
YT Forums
Discount Parts
[Home]
This is the modern view of the Today's Tractors Forum. Just login with your YT Userid and password to post. If you have trouble logging in, contact us by email to support at ytmag.com, or through the Reader Form, and we will get you going right away.
Click here to return to Yesterday's Tractors Forum Index
NH TC33D losing power
Post new topic    Today's Tractors Forum Index -> Today's Tractors
ravenrock6
PostPosted: Thu Mar 17, 2011 2:38 pm    Post subject: NH TC33D losing power Reply to specific post Reply with quote
My nornally reliable TC33D is feeling like me. It loses power and starts audibly missing after it warms up. It loses power/rpm and stalls or dies. I drained/cleaned the fuel filter and bled the line. No change.
Tx Jim
PostPosted: Fri Mar 18, 2011 3:52 am    Post subject: Re: NH TC33D losing power Reply to specific post Reply with quote
Have you checked for good fuel flow coming from tank to filter?
Jerry/MT
PostPosted: Fri Mar 18, 2011 6:44 am    Post subject: Re: NH TC33D losing power Reply to specific post Reply with quote
I agreee with the first post. Often times there is crud in the strainer/tank valve that restricts the flow. It"s easy enough to check. Shut the tank valve, disconnect the line from the tank to the filter and holding a container under the line tur on the tank valve.If the flow dribbles or i intemittent instaead of steadiy runnning out, you"vefound the problem.
the other possibility is that you have a loose fitting that"s allowing air into the fuel line. nae sure the fittings are tight.
ravenrock6
PostPosted: Fri Mar 18, 2011 12:57 pm    Post subject: Re: NH TC33D losing power Reply to specific post Reply with quote
I checked the fuel line. Flow from tank is good and fuel looked ok. I cleaned and drained the fuel filter, bled the line and restarted the tractor. Same thing. After running for 15-20 minutes, the engine starts dying as if fuel had run out, then surges back to normal speed, then starts dying again losing all power. After doing this for 4-5 times, the engine dies. It will start then immediately die. If I let it set for 30 minutes, it starts fine. Thx for helping.
ravenrock6
PostPosted: Fri Mar 18, 2011 12:58 pm    Post subject: Re: NH TC33D losing power Reply to specific post Reply with quote
Jerry/MT
PostPosted: Fri Mar 18, 2011 8:33 pm    Post subject: Re: NH TC33D losing power Reply to specific post Reply with quote
Is the vent in the cap open? if it"s cloggedit will give you intermittent fuelflow. Are you sure you don"t have debris in the fuel tank?
russ1
PostPosted: Sun Mar 20, 2011 4:43 am    Post subject: Re: NH TC33D losing power Reply to specific post Reply with quote
If the fuel has been in the tank for a while it will sometimes allow a fungus to grow and it will clog the filter. You could have flow to the filter but the algae will clog it quickly. You might try draining the tank and putting some new fuel in, change the filter then try it. Sometimes a fungicide is necessary.
RodinNS
PostPosted: Sun Mar 20, 2011 5:03 pm    Post subject: Re: NH TC33D losing power Reply to specific post Reply with quote
Remove the tank cap before you start it and see how long it runs... or when it quits... remove the cap immediately and listen for a hiss/vacuum as you open the cap. I suspect the vent is plugged.
Otherwise you need to check fuel flow into the pump manifold when it quits.
Rod
ravenrock6
PostPosted: Fri Apr 08, 2011 4:37 am    Post subject: Re: NH TC33D losing power Reply to specific post Reply with quote
Turned out to be bad fuel.
bobj984
PostPosted: Thu Aug 24, 2017 7:29 am    Post subject: Re: NH TC33D losing power Reply to specific post Reply with quote
I am having the same problem with my 33d. I used an air hose to blow back up into the fuel line going to the tank and it ran fine for about 10 minutes, then started dying again once I started going uphilll, so that means the tank will have to be removed and cleaned out.
QUESTION:
How do you gain access to the tank to remove it? There are no videos or online manuals showing what you remove to reach the tank, and I don't want to start going through the dash if you need to go through the firewall
Any ideas?
Post new topic    Today's Tractors Forum Index -> Today's Tractors All times are GMT - 8 Hours
Advertisement
Repair/Service manuals available for Allis, Ford, Farmall, John Deere and most other makes and models of tractors. If you are expecting to make repairs to your tractor, check our large online catalog of manuals. We probably have just what you need! Current Special - FREE book offer.    [Click here to visit this Sponsor]
Home | Manuals | Parts
Reproduction of any part of this website, including design and
content, without written permission is strictly prohibited.
Copyright © 1997-2013 TodaysTractors.com
Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others.
