970 noise/vibration when steering with PTO on.
petebert
PostPosted: Fri Jun 04, 2021 8:38 am    Post subject: 970 noise/vibration when steering with PTO on. Reply to specific post Reply with quote
970 with powershift. I was mowing hay and noticed there was a grindy kind of rhythmic noise in the turn-arounds. I could feel it in the steering wheel and at my feet. It would smooth out after going straight for a while and come back at every turn around. When I turned the PTO off it immediately smoothed out.
chuck machinist
PostPosted: Fri Jun 04, 2021 12:12 pm    Post subject: Re: 970 noise/vibration when steering with PTO on. Reply to specific post Reply with quote
Could you be a little more specific, a pull behind mower, or hitch mounted? CM
LPakiz
PostPosted: Fri Jun 04, 2021 2:04 pm    Post subject: Re: 970 noise/vibration when steering with PTO on. Reply to specific post Reply with quote
petebert wrote:
(quoted from post at 17:38:04 06/04/21) 970 with powershift. I was mowing hay and noticed there was a grindy kind of rhythmic noise in the turn-arounds. I could feel it in the steering wheel and at my feet. It would smooth out after going straight for a while and come back at every turn around. When I turned the PTO off it immediately smoothed out.
It could be a universal joint in the PTO driveline.
Check them all for looseness/movement. If nothing shows up, run it for a bit, 15 minutes at least. Many times with a faulty joint, one of the 4 bearings will be hotter than the other 3.
petebert
PostPosted: Fri Jun 04, 2021 3:53 pm    Post subject: Re: 970 noise/vibration when steering with PTO on. Reply to specific post Reply with quote
It's a New Holland 499 swingarm haybine, so no PTO shaft. A hydraulic pump attaches to your PTO. That's why I figure it was tractor related. I was not able to duplicate the noise/vibration without the haybine attached to the tractor.
097Clint
PostPosted: Sat Jun 05, 2021 2:30 pm    Post subject: Re: 970 noise/vibration when steering with PTO on. Reply to specific post Reply with quote
Pete,mine did that when the suction hose was getting bad.when I turned,it would collapse and the pump would cavitate.might not be your, problem,but could be a place to look.
Clint
Mike Fitz
PostPosted: Sun Jun 06, 2021 6:22 am    Post subject: Re: 970 noise/vibration when steering with PTO on. Reply to specific post Reply with quote
Could it be something in the mowers hydraulic drive that changes when you turn,sending a vibration back through the tractor? perhaps some kind of bypass valve chatter?
petebert
PostPosted: Mon Jun 07, 2021 4:34 am    Post subject: Re: 970 noise/vibration when steering with PTO on. Reply to specific post Reply with quote
I'm going to check the mower more. I ran the round baler yesterday and the 970 seemed to do fine.
