anti freeze in oil
cj gun
PostPosted: Tue Jun 08, 2021 12:01 pm    Post subject: anti freeze in oil Reply to specific post Reply with quote
1948 ac mod c. af leakrd into oil, I replaced head gasket and head frost pugs, ran good no leaks. shut off motor no leaks without starting checked oil 2 days later no leaks. Ithoght everything is good until 2 days later without starting motor i checked oil and there was 2 gallons of antifreeze in oil, can somebody please give me an idea of where af is getting into the engine
old
PostPosted: Tue Jun 08, 2021 12:13 pm    Post subject: Re: anti freeze in oil Reply to specific post Reply with quote
Since it is a wet sleeve engine good chance one of if not more of the sleeve o-rings have gone bad. Easy way to check is pull the oil pan and have the cooling system full. Lay a piece of card board under it and watch for coolant on the cardboard.
derwen1959
PostPosted: Tue Jun 08, 2021 12:59 pm    Post subject: Re: anti freeze in oil Reply to specific post Reply with quote
Have you run engine without coolant? As this will
ruin liner seals or liners could be corroded
mdm1
PostPosted: Wed Jun 09, 2021 2:55 am    Post subject: Re: anti freeze in oil Reply to specific post Reply with quote
Just had the same thing happen. Had a frost plug pop. They were new plugs also. I would take off the valve cover and take a look.
Aaron SEIA
PostPosted: Wed Jun 09, 2021 3:02 am    Post subject: Re: anti freeze in oil Reply to specific post Reply with quote
To put that much antifreeze in the oil not running, it's almost guaranteed to be sleeve o-rings. The freeze plugs in the head are also a common issue rusting out, but wouldn't put that much in the pan.
AaronSEIA
cj gun
PostPosted: Wed Jun 09, 2021 5:03 am    Post subject: Re: anti freeze in oil Reply to specific post Reply with quote
mdm1 wrote:
(quoted from post at 03:55:52 06/09/21) Just had the same thing happen. Had a frost plug pop. They were new plugs also. I would take off the valve cover and take a look thank you ill take a look.
cj gun
PostPosted: Wed Jun 09, 2021 5:05 am    Post subject: Re: anti freeze in oil Reply to specific post Reply with quote
thanks i was sort of afraid of that,that makes sence
