Ford 3000 voltage regulator getting hot
abriz
PostPosted: Thu Jun 03, 2021 8:16 pm    Post subject: Ford 3000 voltage regulator getting hot Reply to specific post Reply with quote
I have a 1970 Ford 3000. I had 2 wires short out and replaced all the wiring w/a new wiring harness. Everything is working, but larger coil on back of voltage regulator was getting hot and smoking. Replaced voltage regulator, but still getting hot. Read that you may need to polarize the generator so I did that by touching wire from bat to fld. Still getting hot. Any ideas on what the problem is?
Bern
PostPosted: Thu Jun 03, 2021 8:58 pm    Post subject: Re: Ford 3000 voltage regulator getting hot Reply to specific post Reply with quote
That's what the resistors on the back of voltage regulators do - they get hot. As in completely normal.
M-MAN
PostPosted: Fri Jun 04, 2021 2:58 am    Post subject: Re: Ford 3000 voltage regulator getting hot Reply to specific post Reply with quote
Check your grounds and battery
condition. Both will cause overcharging
and excessive heat.
Sean in PA
PostPosted: Fri Jun 04, 2021 4:35 am    Post subject: Re: Ford 3000 voltage regulator getting hot Reply to specific post Reply with quote
The generator is what gets polarized, not the VR, and you didn't replace the generator, only the VR, so it shouldn't have needed to be polarized again, but it shouldn't have hurt it to do so.
JMOR
PostPosted: Fri Jun 04, 2021 7:57 am    Post subject: Re: Ford 3000 voltage regulator getting hot Reply to specific post Reply with quote
Sean in PA wrote:
(quoted from post at 08:35:34 06/04/21) The generator is what gets polarized, not the VR, and you didn't replace the generator, only the VR, so it shouldn't have needed to be polarized again, but it shouldn't have hurt it to do so.
"shouldn't hurt", IF he did it right, BUT if he applied batt voltage to the VR Field terminal (not just to gen Field as in failure to disconnect gen to VR field connection), then there is a good possibility that the VR field control contacts were damaged.
abriz
PostPosted: Fri Jun 04, 2021 6:56 pm    Post subject: Re: Ford 3000 voltage regulator getting hot Reply to specific post Reply with quote
How hot is normal? Old one was smoking. New one would burn your finger if you held it there but did not notice any smoking.
JMOR
PostPosted: Fri Jun 04, 2021 9:15 pm    Post subject: Re: Ford 3000 voltage regulator getting hot Reply to specific post Reply with quote
CVPost-abriz wrote:
(quoted from post at 22:56:52 06/04/21) How hot is normal? Old one was smoking. New one would burn your finger if you held it there but did not notice any smoking.
I would measure battery voltage and verify that it is around 14-15 volts and not higher after running at speed for 5 to 10 minutes. I expect that it will be too high and caused by welding the field control contacts closed by doing an improper polarization.
M-MAN
PostPosted: Sat Jun 05, 2021 3:51 am    Post subject: Re: Ford 3000 voltage regulator getting hot Reply to specific post Reply with quote
Burning your finger is not normal. To me normal is just warm.
Bern
PostPosted: Sat Jun 05, 2021 5:07 am    Post subject: Re: Ford 3000 voltage regulator getting hot Reply to specific post Reply with quote
I've never measured it, nor have I ever stuck my fingers on one. I do know that I've seen many new VRs smoke as the shipping oils get burned off of them. So that's very likely too hot to touch.
Unless those resistors are glowing red hot and about ready to start a fire, I'd leave it alone and move on with life if the system is otherwise charging normally at 14ish volts.
JMOR
PostPosted: Sat Jun 05, 2021 8:37 am    Post subject: Re: Ford 3000 voltage regulator getting hot Reply to specific post Reply with quote
Bern or anyone else with RB340 regulator, can you measure the value of the larger (longer center tapped resistor) called "swamping resistor" . Measure from center to either end. Both ends are ground. Thank you. All wires disconnected from reg.
JMOR
PostPosted: Sun Jun 06, 2021 7:42 am    Post subject: Re: Ford 3000 voltage regulator getting hot Reply to specific post Reply with quote
JMOR wrote:
(quoted from post at 12:37:29 06/05/21) Bern or anyone else with RB340 regulator, can you measure the value of the larger (longer center tapped resistor) called "swamping resistor" . Measure from center to either end. Both ends are ground. Thank you. All wires disconnected from reg.
abriz or anyone with an RB340 VR handy, could you measure this center tapped resistor for me. I have been into many VRs, but this "swamping resistor" is new to me and am interested in the implementation. The other resistor (Field-to-ARM) is believed to be ~60 Ohms, but have seen no values on the 'swamping resistor'. Thank you.
JMOR
PostPosted: Sun Jun 06, 2021 3:20 pm    Post subject: Re: Ford 3000 voltage regulator getting hot Reply to specific post Reply with quote
JMOR wrote:
(quoted from post at 11:42:10 06/06/21)
I eventually found the answer to values and calculated the normal current thru the "swamp resistor" pair to be 0.65 ampere , thus a power dissipation of about 5.8 Watts. The old time Christmas tree bulbs were 3 Watts and are no more than just warm to the touch & has no heat sink as does this resistor via the terminal connections. If as hot as posted, then battery voltage surely must be far too high. I would actually measure at the ARMATURE, just in case the cut out contacts are not closing as they should.
M-MAN
PostPosted: Tue Jun 08, 2021 5:11 pm    Post subject: Re: Ford 3000 voltage regulator getting hot Reply to specific post Reply with quote
I had to check the temperature of the vr
on my 851d just to be sure. It was a
little warm after running about 45
minutes but no where near hot. I know
this one is a different set up but
still.
JMOR
PostPosted: Thu Jun 10, 2021 1:58 pm    Post subject: Re: Ford 3000 voltage regulator getting hot Reply to specific post Reply with quote
CVPost-M-MAN wrote:
(quoted from post at 21:11:08 06/08/21) I had to check the temperature of the vr
still.
Neither should get HOT. Yours should have heat input around 5 Watts and the RB340 around 8 Watts, neither of which is significant on an item the physical size of a regulator.
I wish he had followed up, as I am still curious as to what was causing such heat as he described. It just about has to be too high a voltage at armature.
