alternator/generator for super C
Charlie M
PostPosted: Fri Jun 11, 2021 3:26 pm    Post subject: alternator/generator for super C Reply to specific post Reply with quote
The generator on my Super C wasn't working when I bought the tractor and I put on an alternator and made the system 12 volts. Problem is the alternator I have has to be cobbled up for the bracket so my cultivators don't hit it. My question is there an alternator people have used that will let the cultivators go past it. I was thinking about putting a 12 volt generator on the tractor but I can't find parts for the one I have. The number is 1100409 and the field coils are bad. I can't tell if field coils from other generators will cross over and work from information I have found. I definitely want 12 volts from either a generator or alternator. I know alternators are a lot cheaper but I'd like the original look of a generator if possible. In the end I want something that works and doesn't hit the cultivators. Any suggestions?
Janicholson
PostPosted: Fri Jun 11, 2021 5:28 pm    Post subject: Re: alternator/generator for super C Reply to specific post Reply with quote
Hitachi 14321 alternator from mid 198s S21 Nissan pickup has the same wiring and is much smaller. L=terminal 1 S = terminal 2 Jim
Fritz Maurer
PostPosted: Sat Jun 12, 2021 2:07 pm    Post subject: Re: alternator/generator for super C Reply to specific post Reply with quote
Why dont you take it to a starter shop and let them figure it out? I just had a starter for a WD-45 fitted with 12 volt fields, and Im sure you can too. I realize youre talking about generators but the idea is the same. Delco is the easiest to find parts for. Guy at the repair shop probably knows what you need without any numbers.
charlieu
PostPosted: Sat Jun 12, 2021 5:16 pm    Post subject: Re: alternator/generator for super C Reply to specific post Reply with quote
I offer a 12v kit that uses a mini Denso alternator and fits with cultivators. Check out my web site at Charliesrepair..com
View user's profile Visit poster's website
charlieu
PostPosted: Mon Jun 14, 2021 7:43 am    Post subject: Re: alternator/generator for super C Reply to specific post Reply with quote
CVPost-charlieu wrote:
(quoted from post at 02:16:43 06/13/21) I offer a 12v kit that uses a mini Denso alternator and fits with cultivators. Check out my web site at Charliesrepair..com
Here are a couple pictures of a Denso on a Farmall BN.
