24 inch rims on Ford 4000 industrial
Jim.UT
PostPosted: Tue Jun 15, 2021 3:25 pm    Post subject: 24 inch rims on Ford 4000 industrial Reply to specific post Reply with quote
My B-I-L has an early 60s 4 cylinder Ford 4000 light industrial with 24 rims. One of them is rotted and he's trying to find a
replacement. He found one in a scrapyard 300 miles away. They are telling him it is a loop rim but the rims he has don't look
like loop rims. Please click the link to see pics he took of what he has.
Can anyone ID the rims he has?
Can you tell if a loop rim will work with this center section?
Does anyone else have a rim (or two) that will work?
We plan to pull the pie weights off in the next couple of days to get a better look at that he has.
Thanks!
Kirk-NJ
PostPosted: Thu Jun 17, 2021 12:37 am    Post subject: Re: 24 inch rims on Ford 4000 industrial Reply to specific post Reply with quote
Jim
The rim you have is an industrial rim. I don't think the standard 6 loop will fit your centers. once you get the rim off the tractor you can send me some measurements, cause I have a standard 6 loop 24 and I will take some measurements to see if it will cross over but I have my doubts. If scrapyard has the 6 loop with the center it should work
Jim.UT
PostPosted: Thu Jun 17, 2021 3:56 pm    Post subject: Re: 24 inch rims on Ford 4000 industrial Reply to specific post Reply with quote
Kirk, Took the wheel apart today. Ultradog gave me a measurement of a loop rim the other night on the phone. This center disk won't fit a loop rim. Confirmed that today. B-I-L is now in search of a double bevel 24x12 industrial rim. When he finds one I'll go back and help him put it back together.
Thanks for the offer!
derwen1959
PostPosted: Fri Jun 18, 2021 8:17 am    Post subject: Re: 24 inch rims on Ford 4000 industrial Reply to specific post Reply with quote
How bad is your B.I.L rim rusted ?
In the past I have repaired a badly damaged rim on our.
JD 2040 by cutting off the damaged rim and welding on the outer rim from an old major wheel also I repaired our
Corroded dexta wheelrim the same way .... the JD wheel
was damaged by previous owner
