Oil pan pinholes
chhanes
PostPosted: Sat Jun 19, 2021 5:39 pm    Post subject: Oil pan pinholes Reply to specific post Reply with quote
I'm restoring a Farmall M and discovered it has about 6 pin holes in a small region of the oil pan. Did some research and found out this is fairly common. In fact, some of the pans I have seen online show corrosion in this same region. What is the recommended method to repair? At what point do you call it a lost cause?
504
PostPosted: Sat Jun 19, 2021 6:33 pm    Post subject: Re: Oil pan pinholes Reply to specific post Reply with quote
You could braze them,but for the cost I would just find another pan. There are lots of them local,(there are Ms everywhere.) you
just have to ask around and someone will have one.
1946 BN IHC
PostPosted: Sun Jun 20, 2021 3:57 am    Post subject: Re: Oil pan pinholes Reply to specific post Reply with quote
Here is a method that I used with success on the restoration of our our IHC Farmall B N >> the oil pan replacement was dinged badly So I set to with a heating torch and hammers. In the process even though I took all the care I could muster, the metal ruptured. So once I had all the metal in palace to the desired shape, I soldered over the area of the rupture and smoothed it as well as I could. THEN taking high heat type J.B. weld I laid a thickish layer several thin layers, letting complete drying between, and then did the same o the inside over the solder. Then set to work smoothing both sides [ to a lesser extent on the inside as compared to the out side. >>> The result; so far no leaks have emerged. I have used the tractor in both winter and summer conditions here in South West Ontario Canada over the past 5 years. I anticipate no leaks in the future, either [ Make certain to follow all instructions on the package including per cleaning thoroughly with either de greaser and or reducer several times before working on the pan.]
Hope this helps.
Wm.
Stephen Newell
PostPosted: Sun Jun 20, 2021 6:10 am    Post subject: Re: Oil pan pinholes Reply to specific post Reply with quote
If it has six holes you can see there is probably a hundred more which are in the making. I would be inclined to remove the pan and thoroughly wash and degrease it and coat it with a fuel tank liner. The liner would plug the existing holes while prevent further
rusting.
wore out
PostPosted: Sun Jun 20, 2021 9:11 am    Post subject: Re: Oil pan pinholes Reply to specific post Reply with quote
If a can't good used pan can't be found at a decent price I would solder over the entire pitted area.
Would have to be cleaned up VERY well, but would be a permanent "non-plastic" repair.
Post new topic    Yesterday's Tractors Forum Index -> Paint and Bodywork All times are GMT - 8 Hours
