KEF engine in a KT?
T.R.K.
PostPosted: Sat Jun 19, 2021 6:06 pm    Post subject: KEF engine in a KT? Reply to specific post Reply with quote
Daydreaming brainstorming, whatever: Either this has been done, or somebody knows why it won't work.
Has anyone ever put a MM KEF engine in a Twin City KT? If so, what did you do to make it work?
I'm thinking the issues would fall in three categories:
Clutch? Will the KT clutch work in the KEF flywheel? Or will the KT flywheel fit on the KEF engine so you can use the KT clutch? But no ring gear on the KT flywheel.
Starter? KT is crank start. Will the KT transmission case miss the chunk of iron cut from it so that the KEF starter can be mounted? (without busting completely apart, of course!)
Front end/radiator/bolster/axle? Can the KT bolster be mounted to the KEF? Would it take a special fan, or would you have to use the KT water pump/flat belt/fan assembly?
Just thinking about it.
Thanks for any thoughts.
T.R.K.
molinegb
PostPosted: Sun Jun 20, 2021 6:10 am    Post subject: Re: KEF engine in a KT? Reply to specific post Reply with quote
Can't see why it wouldn't work. Not sure why you would want to. Top end same. Cranks and bearings not. Have both here apart.
