188 Diesel Question
connor9988
PostPosted: Tue Jun 22, 2021 10:39 am    Post subject: 188 Diesel Question Reply to specific post Reply with quote
What was the first tractor model offered with the 188 diesel engine?
Thanks!
mEl
PostPosted: Tue Jun 22, 2021 10:49 am    Post subject: Re: 188 Diesel Question Reply to specific post Reply with quote
I have never seen one earlier than the 430-530, probably around 60-61, I have an early 530 12 speed with the single fuel filter underneath the tank, later they went to the filters behind the injection pump. Just for fun I put a turbo on mine, hills do not bother it any more. LOL
1370rod
PostPosted: Tue Jun 22, 2021 6:53 pm    Post subject: Re: 188 Diesel Question Reply to specific post Reply with quote
Mel if you do not mind could you post a pic or two of your turbo installation sometime. I would like to do that to the 570, sounds like fun. Since adding a turbo to the
770 the performance attitude really made it a fun little tractor to use. Rod.
connor9988
PostPosted: Tue Jun 22, 2021 7:53 pm    Post subject: Re: 188 Diesel Question Reply to specific post Reply with quote
Could you not get a 500b or 600b with the 188?
Also, not that I would or am in a position to do so but what hurdles would a person run into putting a 188 diesel in a 311 round nose?
You would have to account for the slightly longer block and the 3 bolt starter. As for the injection pump I am unsure if there would be enough room behind the sheet metal without flaring it.
I would think the fan would line up with the radiator just as the gas did.
running the air intake tube would be another challenge.
And looking at the parts breakdown of a 311 and a 530 with the 188 the majority of the throttle connection components are identical so little fabrication would be needed.
Just hypothetical thoughts.
Roger Link
PostPosted: Wed Jun 23, 2021 4:26 am    Post subject: Re: 188 Diesel Question Reply to specific post Reply with quote
On a round nose 300 the top 2 bolts that hold the motor on the torque tube are spaced closer together
connor9988
PostPosted: Thu Jun 24, 2021 7:20 pm    Post subject: Re: 188 Diesel Question Reply to specific post Reply with quote
Thank you guys!
