Ford 4500 and Ford 2910 injection pump swap
mikewood869
PostPosted: Thu Jun 24, 2021 6:37 pm    Post subject: Ford 4500 and Ford 2910 injection pump swap Reply to specific post Reply with quote
Does anyone know if you could swap a injection pump from a 4500 to a 2910? The only thing different seems like the return line (on a 4500, its on the side, while its on the top on a 2910). Or is it possible to swap the top covers on the injection pump from a 4500 to 2910 injection pump?
Sean in PA
PostPosted: Fri Jun 25, 2021 3:20 am    Post subject: Re: Ford 4500 and Ford 2910 injection pump swap Reply to specific post Reply with quote
The pump will fit, but the 2910 has a smaller displacement engine (175 ci vs. 201 ci) and less hp (36 vs. 53 tested PTO hp), so the pump from a 4500 would be delivering almost 50% more fuel than the engine in the 2910 wants. I'm not an expert on diesel injection pumps, but the pump would probably have to be modified, either via adjustments or via replacement of parts to lower the amount of fuel being delivered.
Dieseltech
PostPosted: Fri Jun 25, 2021 3:22 am    Post subject: Re: Ford 4500 and Ford 2910 injection pump swap Reply to specific post Reply with quote
Full load fuel setting is higher on the 4500/201 engine pump, top cover spring code setting may not be the same either.
Al Baker(pumpman)
PostPosted: Fri Jun 25, 2021 5:54 pm    Post subject: Re: Ford 4500 and Ford 2910 injection pump swap Reply to specific post Reply with quote
It will work, but you might not like how well it runs. Same pump, different settings, for different engine. Al
