101 Davis loader Used on Ford tractors
TedinNE
PostPosted: Wed Oct 13, 2021 6:38 am    Post subject: 101 Davis loader Used on Ford tractors Reply to specific post Reply with quote
Anyone know where to get parts for a double action control valve. Would also consider a complete used valve.
Thank you for any help,
Ted
wore out
PostPosted: Wed Oct 13, 2021 7:53 am    Post subject: Re: 101 Davis loader Used on Ford tractors Reply to specific post Reply with quote
CVPost-TedinNE wrote:
(quoted from post at 07:38:55 10/13/21) Anyone know where to get parts for a double action control valve. Would also consider a complete used valve.
Ted
What parts do you need, the spools and body are usually considered a "matched set" and not available separately even when "new".
Do you need seals or springs? Or?
TedinNE
PostPosted: Wed Oct 13, 2021 8:12 am    Post subject: Re: 101 Davis loader Used on Ford tractors Reply to specific post Reply with quote
Need centering springs and valve spool seals. Spool seal appears to be a drive in lip thpe seal. Do not have it apart.
TheOldHokie
PostPosted: Wed Oct 13, 2021 11:53 am    Post subject: Re: 101 Davis loader Used on Ford tractors Reply to specific post Reply with quote
(quoted from post at 10:38:55 10/13/21) Anyone know where to get parts for a double action control valve. Would also consider a complete used valve.
Ted
You can buy a new valve for less than $100.
Dan
Jim.ME
PostPosted: Wed Oct 13, 2021 1:02 pm    Post subject: Re: 101 Davis loader Used on Ford tractors Reply to specific post Reply with quote
If you remove the seals you may be able to match them up at a seal supplier. As for the springs that will be a crap shoot. I tried a couple numbers from the parts book I posted for you and got no hits (see your post on the MF forum). I believe a new valve is your best option. Given the vintage of these valves, a used valve may just get you a second valve with problems.
wore out
PostPosted: Wed Oct 13, 2021 6:39 pm    Post subject: Re: 101 Davis loader Used on Ford tractors Reply to specific post Reply with quote
TheOldHokie wrote:
(quoted from post at 12:53:29 10/13/21)
Ted
Dan
TOH, if his valve is like the one I am familiar with (pictured below) it is "purpose built" and fits nicely against the angled face of the loader mount that also serves as the hydraulic reservoir.
Return oil flows out of the valve at the mounting area and returns to the reservoir with no external connections/lines.
IF the O.P. can find lip seals for the spools (I'm pretty sure there's a thread on this in the archives somewhere with part numbers) and find generic replacements for the spool centering springs the end result will be nicer than trying to adapt a modern, generic, valve.
The way the spool centering springs work there's a little leeway in replacing them with generic compression springs.
TedinNE
PostPosted: Wed Oct 13, 2021 6:55 pm    Post subject: Re: 101 Davis loader Used on Ford tractors Reply to specific post Reply with quote
Thank you everyone for all the replies. wore out the valve you picture is like mine. I have located the spool seals. As you say I
think I can use a generic spring and make it work. The lift spool spring must be weak or broken Have to help center it. Spool is
free.
Ted
Hidude
PostPosted: Wed Oct 13, 2021 8:59 pm    Post subject: Re: 101 Davis loader Used on Ford tractors Reply to specific post Reply with quote
I know you said you found the seals but ill jump in with this. Cr7440 is what I used. Can't remember if thats a single or double lip seal though. Mine may be a little different than yours. I have a davis 102a
TheOldHokie
PostPosted: Thu Oct 14, 2021 2:48 am    Post subject: Re: 101 Davis loader Used on Ford tractors Reply to specific post Reply with quote
wore out wrote:
(quoted from post at 22:39:26 10/13/21)
Ted
Dan
Ahh yes - I have seen them before. They are a PITA design. I'd still replace it with a new one and put a cover plate and return fitting on the tank.
TOH
Tom/Idaho
PostPosted: Thu Oct 14, 2021 8:33 am    Post subject: Re: 101 Davis loader Used on Ford tractors Reply to specific post Reply with quote
Where did you find that exploded picture of the valve?
Do you have a manual? My loader has that exact valve.
Thank you,
Tom/Idaho
TheOldHokie
PostPosted: Thu Oct 14, 2021 9:40 am    Post subject: Re: 101 Davis loader Used on Ford tractors Reply to specific post Reply with quote
CVPost-Tom/Idaho wrote:
(quoted from post at 12:33:43 10/14/21) Where did you find that exploded picture of the valve?
Thank you,
Tom/Idaho
The dealer parts manual can be downloaded from the N tractor club website.
TOH
Tom/Idaho
PostPosted: Thu Oct 14, 2021 3:42 pm    Post subject: Re: 101 Davis loader Used on Ford tractors Reply to specific post Reply with quote
TOH, thank you.
Tom/Idaho
