ferguson to 20 starter problems
Twilhelmsen
PostPosted: Fri Jan 14, 2022 11:53 am    Post subject: ferguson to 20 starter problems Reply to specific post Reply with quote
Hello all, this is my first time ever posting on this and I wanted to get a feel for it. I have a 1951 Ferguson TO 20 and it was running great yesterday but I went out this
morning to go to start it and I hear the starter spinning when I put it in the gear S but it is not engaging
I have read a lot and it doesn't seem like a starter button switch problem or a battery/cable problem.
anyone know what it might be
John Deere D
PostPosted: Fri Jan 14, 2022 9:35 pm    Post subject: Re: ferguson to 20 starter problems Reply to specific post Reply with quote
Turn engine over/ rotate engine IE. HAND Crank...or place transmissional gear and push Tractor forward...there is a possibly a tooth and or teeth on the flywheel are worn paddle in one spot..?
Remove Starter and inspect starter drive...starter drive may be of an over-running clutch design / Bendix.
Drive may be worn out.? Starter drives are often a ONE WAY drive design. They must lock up to start engine and release after Engine is running.
Remove starter and inspect all teeth on Flywheel..
Bob.
Twilhelmsen
PostPosted: Sat Jan 15, 2022 6:18 pm    Post subject: Re: ferguson to 20 starter problems Reply to specific post Reply with quote
thank you
it was the starter drive even though the starter was just rebuilt
do you know where i can buy a new starter
John Deere D
PostPosted: Sat Jan 15, 2022 10:26 pm    Post subject: Re: ferguson to 20 starter problems Reply to specific post Reply with quote
Only a suggestion......
If you are in the USA...this site YESTERDAYS TRACTORS sells starters......
If you reside in a location that rebuilds starters that would be my first choice.....:)
You could purchase the overrunning clutch only.....
Be sure you know ..
Do you require a 6 Volt starter or a 12 Volt starter...?
Was your Tractor a FACTORY 6 Volt starter that now has a 12 volt system???
Bob..
lugnuts2030
PostPosted: Sun Jan 16, 2022 5:57 am    Post subject: Re: ferguson to 20 starter problems Reply to specific post Reply with quote
If its a bad tooth on ring gear? This will happen when ever that bad tooth lines up with starter gear. I have a tractor that does this, My remedy is to grab fan blade and turn engine slightly and problem solved.
This doesn,t happen often and not certaintly not worth splitting tractor to replace ring gear.
