cat 941 track adjustor help
373
PostPosted: Thu May 12, 2022 4:25 am    Post subject: cat 941 track adjustor help Reply to specific post Reply with quote
Help..piston is stuck in the cylinder . I tried pulling on the front idler with a chain to free it up . That didnt work . I have since compressed the spring and unbolted the assembly from the loader. Any suggestions ? Can I use some heat ? I cant remove the rod from the cylinder because the bolts are close to the cylinder head. I could back them out and cut off the bolt heads if I had to .
dpendzic
PostPosted: Thu May 12, 2022 1:21 pm    Post subject: Re: cat 941 track adjustor help Reply to specific post Reply with quote
I freed mine by soaking with kroil oil and then pulling it back IN first--i think it got cocked crooked and jammed in---then pulled it out and resealed it
373
PostPosted: Fri May 13, 2022 7:17 am    Post subject: Re: cat 941 track adjustor help Reply to specific post Reply with quote
Did you submerge the whole thing in oil or just spray it on the head part ? How did you get it to pull out ? I think mine is jammed all the way in .
dpendzic
PostPosted: Fri May 13, 2022 7:32 pm    Post subject: Re: cat 941 track adjustor help Reply to specific post Reply with quote
I just sprayed it with kroil and it must have self aligned when i retracted it--then pumped grease in it to push the cyl out
