Ford 4000 bad engine leak
Havana7
PostPosted: Thu Sep 22, 2022 9:14 am    Post subject: Ford 4000 bad engine leak Reply to specific post Reply with quote
My Ford 4000 tractor is throwing engine oil out of that
small inspection plate left side on the bellhousing ,
you can see a little smaller gear in there , it just
pumps it out as the engine is running any idea before I
split it. Would a rear seal throw that much out so fast ,
10 seconds a gallon of oil on the floor. Any help would
be greatly appreciated. Thanks
Sean in PA
PostPosted: Thu Sep 22, 2022 2:55 pm    Post subject: Re: Ford 4000 bad engine leak Reply to specific post Reply with quote
I assume that this is a 3 cylinder 4000. That "inspection cover" covers the hole where the engine mounted hydraulic pump would mount on models that do not have independent PTO. The gear inside is what would drive the pump. The gear is on the rear end of the camshaft. It is inside the part of the engine that should receive lubrication, so there should be oil in there. The cover should have a gasket under it and it should have 4 bolts holding it in place that should be screwed down good and tight to prevent oil from leaking. First thing I would do is get a new gasket (part number 81822547) and tighten down all 4 of the bolts and see if it continues to leak. Messicks.com says they have 16 of the gaskets in stock, so you should be able to get one from them or any New Holland dealer. If it still leaks, then the cover may be warped or bent, or the surface on the block around the hole may not be flat and even, or either of the mating surfaces may need to be scraped clean of any old gasket material.
shaun wallace
PostPosted: Thu Sep 22, 2022 3:38 pm    Post subject: Re: Ford 4000 bad engine leak Reply to specific post Reply with quote
As Sean says there is oil present but there is a pressure port that supplied oil to engine mounted hyd pump that would leak. It has 30-60 psi oil pressure supplied to it,
Havana7
PostPosted: Thu Sep 22, 2022 5:17 pm    Post subject: Re: Ford 4000 bad engine leak Reply to specific post Reply with quote
Forgot to add sir it drain all the oil out of my engine oil pan. Good thing I stopped it right away cant be normal
Havana7
PostPosted: Thu Sep 22, 2022 5:19 pm    Post subject: Re: Ford 4000 bad engine leak Reply to specific post Reply with quote
Yes it is a 3 cylinder gas Mike K
Havana7
PostPosted: Thu Sep 22, 2022 5:51 pm    Post subject: Re: Ford 4000 bad engine leak Reply to specific post Reply with quote
Also forgot to add I had that plate bolted on loosely
never dreamed oil would be coming out of there.
Destroked 450
PostPosted: Fri Sep 23, 2022 4:40 am    Post subject: Re: Ford 4000 bad engine leak Reply to specific post Reply with quote
That plate covers a oil port coming from the main oil galley, leaving the cove plate loose would be like poking a hole in the oil filter
Havana7
PostPosted: Fri Sep 23, 2022 5:22 am    Post subject: Re: Ford 4000 bad engine leak Reply to specific post Reply with quote
Wow am I ever a idiot didnt know any better, will seal
it up hopefully didnt do any damage. Thank you to
everyone who replied to my problem. Mike K
