Crank pulley bolt
Doug 13
PostPosted: Wed Sep 21, 2022 7:22 pm    Post subject: Crank pulley bolt Reply to specific post Reply with quote
Would it be ok to change slotted bolt for a regular fine threaded bolt?
Den N Ms
PostPosted: Thu Sep 22, 2022 3:05 am    Post subject: Re: Crank pulley bolt Reply to specific post Reply with quote
Doug 13 , I would rather have the crank bolt than a regular bolt.
So you can use a crank to turn the engine over for tune up work such as distributor work or setting valve lash.
Abbby
PostPosted: Thu Sep 22, 2022 3:32 am    Post subject: Re: Crank pulley bolt Reply to specific post Reply with quote
Will work just fine.
Hobo,NC
PostPosted: Thu Sep 22, 2022 5:52 am    Post subject: Re: Crank pulley bolt Reply to specific post Reply with quote
Depending on the style pully used it may need a harden washer between the bolt hex head and pully.
lha
PostPosted: Thu Sep 22, 2022 8:23 am    Post subject: Re: Crank pulley bolt Reply to specific post Reply with quote
I have used my crank for starting my 9n several times when my battery was discharged. It works well. I used
the same crank handle that came on my '48 Dodge truck.
DMartin9N-2N
PostPosted: Thu Sep 22, 2022 11:23 am    Post subject: Re: Crank pulley bolt Reply to specific post Reply with quote
Good afternoon, lha: I have a 9N, and I also have a 1945 Dodge 1/2 ton truck with a crank. Maybe the crank will work in the 9N? Interesting thought.....
Dennis M. in W. Tenn.
wore out
PostPosted: Thu Sep 22, 2022 12:06 pm    Post subject: Re: Crank pulley bolt Reply to specific post Reply with quote
DMartin9N-2N wrote:
(quoted from post at 12:23:04 09/22/22) Good afternoon, lha: I have a 9N, and I also have a 1945 Dodge 1/2 ton truck with a crank. Maybe the crank will work in the 9N? Interesting thought.....
''I also have a 1945 Dodge 1/2 ton truck with a crank. Maybe the crank will work in the 9N? Interesting thought..... ''
Actually, MANY cranks were interchangeable in the old days, it would be more of an ''oddball event'' to find one that WOULDN'T fit vs. one that WOULD fit, LOL!
TheOldHokie
PostPosted: Thu Sep 22, 2022 1:54 pm    Post subject: Re: Crank pulley bolt Reply to specific post Reply with quote
Doug 13 wrote:
(quoted from post at 23:22:03 09/21/22) Would it be ok to change slotted bolt for a regular fine threaded bolt?
Yes.
TOH
lha
PostPosted: Thu Sep 22, 2022 2:10 pm    Post subject: Re: Crank pulley bolt Reply to specific post Reply with quote
I got rid of my old Dodge when someone wanted it more than I did,but somehow kept the crank. Several days,I drove to work when it was dark in the morning,left the lights on,then to the delight of co-workers,cranked it by hand and drove home. Some teased me about the old relic,but were glad when I pulled them out of the mud after a day of rain. I live in W.Tn as well,outside of Jackson about 10 miles.
Doug 13
PostPosted: Thu Sep 22, 2022 6:00 pm    Post subject: Re: Crank pulley bolt Reply to specific post Reply with quote
Den N Ms wrote:
(quoted from post at 04:05:19 09/22/22) Doug 13 , I would rather have the crank bolt than a regular bolt.
Yes, good idea using a crank bolt for maintenance. I think I can buy it and a crank handle.
Den N Ms
PostPosted: Fri Sep 23, 2022 1:02 am    Post subject: Re: Crank pulley bolt Reply to specific post Reply with quote
Doug 13 wrote:
(quoted from post at 19:00:39 09/22/22) [quote="Den N Ms"](quoted from post at 04:05:19 09/22/22) Doug 13 , I would rather have the crank bolt than a regular bolt.
Yes, good idea using a crank bolt for maintenance. I think I can buy it and a crank handle.[/quote]
Yes this great site has them.
SOM TING WONG LOL
This post was edited by Den N Ms on 09/23/2022 at 02:52 am.
Den N Ms
PostPosted: Fri Sep 23, 2022 1:04 am    Post subject: Re: Crank pulley bolt Reply to specific post Reply with quote
https://www.yesterdaystractors.com/Ford-8N_Crankshaft-Cranking-Ratchet_2N6319A1.html
https://www.yesterdaystractors.com/Ford-8N_Hand-Starting-Crank_351010R31.html
