Author |
Message |
AlinMO Regular
Joined: 31 Aug 2015 Posts: 351 Location: Western Missouri
Posted: Tue Jan 24, 2023 11:47 am Post subject: Re: IH 350 Utility is Broke |
Search for Continental GD193, quite a few parts available. Also try JP Tractor Salvage in MIssouri. |
Back to top |
Tom in Mo. Long Time User
Posted: Tue Jan 24, 2023 2:28 pm Post subject: Re: IH 350 Utility is Broke |
Monte's Equipment had all the Continental parts near Chicago if they are still in business.
I had this happen with a Ford. The pump locked up and sheared the teeth off the rear of the cam gear along with a few off the front gear. |
Back to top |
rustred Tractor Guru
Posted: Tue Jan 24, 2023 7:30 pm Post subject: Re: IH 350 Utility is Broke |
i am sure the guy that sold it knew something you didnt know. that just did not happen since you owned it. you just finished it off. |
Back to top |
nashranch Tractor Expert
Posted: Tue Jan 24, 2023 7:51 pm Post subject: Re: IH 350 Utility is Broke |
The guy who owned it was deceased. I bought it from no nothing son in law. No doubt that's why it was parked. I sure the hyd pump quit working so he parked it. I had it running and then that can gear came off and the tractor shut down. I pulled the pan this morning and found the teeth. It didn't hurt the crank gear which is surprising |
Back to top |
Posted: Tue Jan 24, 2023 8:31 pm Post subject: Re: IH 350 Utility is Broke |
I see, long as u can find parts. |
Back to top |
Posted: Mon Jan 30, 2023 5:32 pm Post subject: Re: IH 350 Utility is Broke |
[quote="CVPost-rustred"](quoted from post at 21:31:43 01/24/23) I see, long as u can find parts.[/quote
A big thanks to 1974vette for selling me the gears I needed plus the two push rods. Loctite was my friend on that cam gear nut plus I drilled a hole for a retainer wire. That should hold it
I had to order in a hyd. Pump seal ... about a week out they said
This post was edited by nashranch on 01/31/2023 at 06:14 am.
Back to top |
