Author |
Message |
a49deere Regular
Posted: Mon Sep 18, 2023 1:59 pm Post subject: 906LT |
Hoping someone could tell me the correct length PTO shaft to fit a ford/new holland 906LT
post hole digger? thanks in advance |
Back to top |
caterpillar guy Tractor Guru
Posted: Tue Sep 19, 2023 3:10 am Post subject: Re: 906LT |
As long as it has about 6 inches of lap when extended and does not hit when retracted it should be fine since we are not there you will have to determine this first. With the digger in the extended position put the 2 pieces on their respective places and lay them beside each other measure the lap. then with it in the retracted position see if they would hit at the ends beside each other if not and you have the appropriate lap then go for it. |
Back to top |
BarnyardEngineering Tractor Guru
Posted: Tue Sep 19, 2023 4:21 am Post subject: Re: 906LT |
If you're using Modern View, I have a reply that seems to have been filtered out by it. It's over in Classic view.
In short, tractor supply sells a PTO shaft specifically for 3pt post hole diggers. Odds are it will work on your machine. |
Back to top |
Posted: Tue Sep 19, 2023 4:26 am Post subject: Re: 906LT |
Just did a little poking around in the parts book, and the shaft I linked in the classic view post at TSC will fit. |
Back to top |
Jim.ME Tractor Guru
Posted: Tue Sep 19, 2023 4:45 am Post subject: Re: 906LT |
Your link in Classic shows, but when I click on it this is what I get.
Looks like Modern blocks the whole post and Classic allows the post but blocks the link. |
Back to top |
a49deere Regular
Posted: Tue Sep 19, 2023 4:58 pm Post subject: Re: 906LT |
thanks everyone |
Back to top |
