Author |
Message |
Rich.Fl Regular
Posted: Mon Sep 18, 2023 4:53 pm Post subject: JD 6620 Chaffer and Sieve |
I have had this 6620 for about a year, am new to combines so still on a steep learning curve.
There are sections missing from both the chaffer and the sieve. Are these replaceable/fixable?
Thanks!
Back to top |
casecollectorsc Tractor Guru
Posted: Wed Sep 20, 2023 3:49 am Post subject: Re: JD 6620 Chaffer and Sieve |
Sieve is wore bad and the wires rub thru. Fix one spot and another will wear thru. Look for a better one from a salvage yard. No individual repair parts to fix it. |
Back to top |
flying belgian Tractor Guru
Posted: Thu Sep 21, 2023 2:04 pm Post subject: Re: JD 6620 Chaffer and Sieve |
How many acres you running through it? If just a few I would be tempted to patch holes with a piece of tin. |
Back to top |
8850dave Long Time User
Posted: Fri Sep 22, 2023 6:09 am Post subject: Re: JD 6620 Chaffer and Sieve |
Where are located ? Ive got a new sieve or chauffeur but its more a small grain version |
Back to top |
Rich.Fl Regular
Posted: Fri Sep 22, 2023 6:26 am Post subject: Re: JD 6620 Chaffer and Sieve |
Thanks for the suggestions and replies!
I have found some parts so will see if I can repair it in some fashion: https://www.combineparts.com/Miscellaneous-Sieve-Replacement-Louvre-Short-Finger-NEW-WN-SFLV12
Dave, I am in Florida. |
Back to top |
jon f mn Tractor Guru
Posted: Mon Sep 25, 2023 8:17 pm Post subject: Re: JD 6620 Chaffer and Sieve |
Make sure you replace the rubber bushing the sho runs on. When those get old it causes the sieves to go bad like that. They are available and not expensive. |
Back to top |
Rich.Fl Regular
Posted: Tue Sep 26, 2023 3:37 am Post subject: Re: JD 6620 Chaffer and Sieve |
Jon, Thanks for that suggestion I will do that.
I know so little about combines I am not sure what the shoe is. Is that the frame that holds the chafer?? I attached a picture of that frame but don't see a bushing. Need a little more explanation where the rubber bushing is:)
Thanks!!
Back to top |
4520BW Tractor Guru
Posted: Thu Sep 28, 2023 5:34 am Post subject: Re: JD 6620 Chaffer and Sieve |
like jon said check the shaker arms and bushings. Is it a Titan2 by chance? they are known the shake sieves apart. |
Back to top |
Rich.Fl Regular
Posted: Thu Sep 28, 2023 6:27 am Post subject: Re: JD 6620 Chaffer and Sieve |
Thanks for your comments! It is not a Titan II. I attached a parts diagram of the Sieve Frame. There are 14 bushings (shown as #8 in the diagram.) Are these the bushings that should be replaced?
Back to top |
wore out Tractor Guru
Posted: Thu Sep 28, 2023 7:26 am Post subject: Re: JD 6620 Chaffer and Sieve |
Yes, and when you replace them position the arm they press into at the middle of it's stroke before tightening the bolt through the center so the rubber bushing doesn't get twisted excessively in one direction.
This post was edited by wore out on 09/28/2023 at 10:52 am.
Back to top |
Rich.Fl Regular
Posted: Thu Sep 28, 2023 9:35 am Post subject: Re: JD 6620 Chaffer and Sieve |
Thanks Wore Out! Good information:) |
Back to top |
4520BW Tractor Guru
Posted: Fri Sep 29, 2023 5:59 am Post subject: Re: JD 6620 Chaffer and Sieve |
Thats them. I replaced them in my 7720 and they looked good until i pressed them out. Its not a bad job just time consuming. Coat the new ones with a lil white grease and they will press in alot easier, also get new bolts as they will have wear. |
Back to top |
