Cutting tempered steel
markiz41
PostPosted: Fri Feb 15, 2008 5:24 am    Post subject: Cutting tempered steel Reply to specific post Reply with quote
All,
This is to follow up on the thread about making your own piston pins. I got a 5/8 quenched and ground rod from McMaster, which is exactly what I need. Now I just have to cut it to length. The only means of doing that at my immediate disposal is a chop saw. Or a hand grinder. But I worry about overheating the metal and taking the temper out of it. Any suggestions?
I can have a friend cut this on a lathe or a bandsaw, just a question of time and beer.
Joe(TX)
PostPosted: Fri Feb 15, 2008 5:32 am    Post subject: Re: Cutting tempered steel Reply to specific post Reply with quote
Use the cutoff saw. go slow so there is no color change. ie does not turn blue.
dobber
Guest
PostPosted: Fri Feb 15, 2008 6:26 am    Post subject: Re: Cutting tempered steel Reply to specific post Reply with quote
That's why machine shops have large band saws with coolant pumps and newer cold cut saws now. Abrasive blades will heat the end a lot no matter how slow you try cutting it.
Dick L
PostPosted: Fri Feb 15, 2008 6:42 am    Post subject: Re: Cutting tempered steel Reply to specific post Reply with quote
We cut most of our hard pins in a spin index on a surface grinder using a cutoff wheel. We also use a post grinder using the sharp edge. Grind a vee in just a 1/4 inch or so and put the pin in water and then grind the other side. work around the pin until we can snap it off. When it starts to discolor dip it in water again. easy way to tell is hold the pin about two inches from where you are grinding with your bare hands and you will know when to cool the pin. I have cut hundreds of pins this way. We may put 20 to 30 pins in one mold.
RobMD
PostPosted: Fri Feb 15, 2008 8:15 pm    Post subject: Re: Cutting tempered steel Reply to specific post Reply with quote
Air cutoff wheel and go around the rod in a circular motion, but not continuous. Basically, tap it with the cut off wheel all the way around. AN ice cube helps a LOT.
guido
PostPosted: Sat Feb 16, 2008 11:20 am    Post subject: Re: Cutting tempered steel Reply to specific post Reply with quote
Hello Markiz41
How about you chuck the pin in a drill press,
turn it slow, and cut it with a cut off wheel in the opposite diraction that it is spinning.
If you have to, cut more than you need and dress it up after you cut it.
Guido.
markiz41
PostPosted: Sat Feb 16, 2008 11:55 am    Post subject: Re: Cutting tempered steel Reply to specific post Reply with quote
Great idea. And I can do it too, with an air grinder. Thanks, guys, love this place.
