Author |
Message |
Larry's 41C New User
Posted: Fri Oct 23, 2009 1:13 pm Post subject: Starter problem |
I’m at my wits end on the starter. It would not turn the motor with the plugs in. I took it to an automotive repair shop and he checked the armature, changed brushes and so on. Put it on and the same thing. I put it under no load and as it spun it drained down and I a bolt sparking on a band. I took the bolt out and it turned the motor with plugs in. Thinking I fixed the problem, I took it out to paint the tractor. When I put it back, it would not turn the motor. After a few times taking it apart cleaning and making sure the connections were good with NO result, I bought a good used one off eBay. I got it today and it did the same thing. I even jumped it with a 12V car battery! Let me know of any ideas. |
Back to top |
MLPANKEY Guest
Posted: Fri Oct 23, 2009 1:31 pm Post subject: Re: Starter problem |
with the plugs in and the ignition off will it turn the engine over. |
Back to top |
RENE' Guest
Posted: Fri Oct 23, 2009 2:53 pm Post subject: Re: Starter problem |
WHAT TRACTOR ALLIS NEEDS NO PAINT FOR A GROUND TO MAKE A CIRCUIT. RENE' |
Back to top |
rustred Tractor Guru
Posted: Fri Oct 23, 2009 3:41 pm Post subject: Re: Starter problem |
what tractor is that?if you have a push starter button that may be your problem. |
Back to top |
JMS/.MN Tractor Guru
Posted: Fri Oct 23, 2009 3:55 pm Post subject: Re: Starter problem |
When you painted the tractor, did you paint the hole the starter fits in? You need good contact there to complete the circuit- make that hole shine!, starter case too. |
Back to top |
41C Regular
Posted: Fri Oct 23, 2009 4:25 pm Post subject: Re: Starter problem |
It is a model “C” with a 6V push button system. I have a new switch on mine and after rustred’s reply, I put the new switch on the one from eBay and still the same. Also, I did not paint the starter hole. |
Back to top |
chalmersbob(Pa) Long Time User
Posted: Fri Oct 23, 2009 7:00 pm Post subject: Re: Starter problem |
what size wires do you have on the battery? If they are car type cables they are too light. Have you cleaned the battery connections? Bob |
Back to top |
Posted: Fri Oct 23, 2009 7:36 pm Post subject: Re: Starter problem |
another thing is you may have a bad batt. cable.i have seen that happen.you couldnt tell by looking at it. |
Back to top |
El Toro Tractor Guru
Posted: Sat Oct 24, 2009 8:01 am Post subject: Re: Starter problem |
Put some 00 battery cables on it with soldered lugs and clean all surfaces including where its grounded as paint and rust make good insulators. Hal |
Back to top |
