Author |
Message |
D. New User
Posted: Fri Oct 01, 2010 4:37 pm Post subject: converting combine engine to electric start |
Hello, im thinking about converting an ac 60 combine to electric start. Does anyone know where i could find the parts? i live in lower west Michigan.Thanx Dave |
Back to top |
cbp Regular
Posted: Sat Oct 02, 2010 6:02 am Post subject: Re: converting combine engine to electric start |
I think you will be looking for the B-125 stationary version bell housing. These should be easier to find than asking for one for a 60H but are the same part. The starter mounts at 12 oclock. The B-125 often sold for military use and there were a lot of them around. In my area, navy pull-offs were common. Only problem is that through surplus processes, they may not have made it to tractor scrapyards as often. Talking to used parts dealers about this might be the ticket.
The remainder of the parts are mostly off the shelf rebuilts. |
Back to top |
D. New User
Posted: Sat Oct 02, 2010 6:24 am Post subject: Re: converting combine engine to electric start |
i appreciate the info. i probably should have said stationary engine, but yes i need a bellhousing for a b-125 engine. probably flywheel also. thanx Dave |
Back to top |
steve(ill) Tractor Expert
Posted: Sat Oct 02, 2010 5:30 pm Post subject: Re: converting combine engine to electric start |
the 125 was used in the model B and C tractors. you can probably use a starter, flywheel, and maybe clutch off one of those tractors. THe bell housing on the B-C is part of the torque tube... probably wil not work without some drastic modification. |
Back to top |
Jim Craig New User
Posted: Tue Oct 05, 2010 5:35 pm Post subject: Re: converting combine engine to electric start |
Send me your email and I will send you a photo or two of the bell housing that I have from a stationary B125.. |
Back to top |
D. New User
Posted: Thu Oct 21, 2010 5:01 am Post subject: Re: converting combine engine to electric start |
Sorry about the slow response. i never received my email notification. |
Back to top |
