AC HD 10 steering brake problem
lemmond1
Guest
PostPosted: Thu Jun 28, 2012 5:33 pm    Post subject: AC HD 10 steering brake problem Reply to specific post Reply with quote
I broke the short brake rod on my dozer and welded it back together. Now my brake pedal is stationary on that side. How do I adjust it? Roy
gemdozer
Guest
PostPosted: Fri Jun 29, 2012 10:45 am    Post subject: Re: AC HD 10 steering brake problem Reply to specific post Reply with quote
You should have a small cover on the inspection cover under the fuel tank and you should see the exagon head rod adjustement if the HD10 is the same then the HD11
jm.
PostPosted: Fri Jun 29, 2012 4:19 pm    Post subject: Re: AC HD 10 steering brake problem Reply to specific post Reply with quote
That rod adjustment wil be a funny looking has he calles it exagon looking but they are notorious for twisting off.. go very easy when you try suspect you have more problems because breaking the break rod is not normal I am thinking you will need to reline the brakes.. First dozer I ever owned in my life was a detroit powred cabel hd10 ac. Probably can find the service manual if you need one. jm. E-mail open
lemmond1
Guest
PostPosted: Sat Jun 30, 2012 12:27 pm    Post subject: Re: AC HD 10 steering brake problem Reply to specific post Reply with quote
Thanks for your response. I broke the short rod that is near the floor. A boisd'arc limb caught underneath and caused this. i have cut and welded the rod several times but I don't seem to get it right. The rod is about 18" long. Roy
lemmond1
Guest
PostPosted: Sat Jun 30, 2012 12:34 pm    Post subject: Re: AC HD 10 steering brake problem Reply to specific post Reply with quote
Thank Gem for your help. I have tried adjusting the brake behind the inspection plate you mentioned. The adjusting mechanism doesn't seem to do much toward alleviating this problem. I will keep trying. I have a manual but it doesn't specify the exact length of this rod. Roy
Bill in Colo
PostPosted: Sat Jun 30, 2012 7:14 pm    Post subject: Re: AC HD 10 steering brake problem Reply to specific post Reply with quote
Could you measure the rod on the other side ?
lemmond1
Guest
PostPosted: Sun Jul 01, 2012 2:42 pm    Post subject: Re: AC HD 10 steering brake problem Reply to specific post Reply with quote
Thanks for your response. Yes, I have measured the other side and thought I was getting them the same length. I will try again. Roy
gemdozer
Guest
PostPosted: Mon Jul 02, 2012 2:22 am    Post subject: Re: AC HD 10 steering brake problem Reply to specific post Reply with quote
If your 2 rods are the same long are you adjusted the brake and they not working your brake are to worm or your rod adjustement tread and yoke femelle tread are scrap
lemmond1
Guest
PostPosted: Mon Jul 02, 2012 6:10 pm    Post subject: Re: AC HD 10 steering brake problem Reply to specific post Reply with quote
I remeasured the other side as you suggested and found it to be 3 inches longer. I will add three inches to the side that I broke. Hope this does it. Roy
gemdozer
Guest
PostPosted: Tue Jul 03, 2012 1:26 pm    Post subject: Re: AC HD 10 steering brake problem Reply to specific post Reply with quote
I have a brake rod 21 inchs long 1/2" with fine tread at end and the other end she has a yoke for pine
lemmond1
Guest
PostPosted: Tue Jul 03, 2012 5:32 pm    Post subject: Re: AC HD 10 steering brake problem Reply to specific post Reply with quote
I measured the other side and it was 20" pin to pin. I welded a threaded bolt on the side I broke to 20". The brake pedal sets up way too high and the brake still does'nt work. I took 1 and 1/2 inches off the rod and rewelded. It still doesn't work. I am going to try to adjust it from the rear inspection plate. Roy
lemmond1
Guest
PostPosted: Tue Jul 03, 2012 5:35 pm    Post subject: Re: AC HD 10 steering brake problem Reply to specific post Reply with quote
The steering brake worked just fine before I broke it. The brake shoes look good. Roy
lemmond1
Guest
PostPosted: Wed Jul 04, 2012 12:58 pm    Post subject: Re: AC HD 10 steering brake problem Reply to specific post Reply with quote
I think a new set of brak3 shoes would help. Does anyone know where I might get some new brake shoes? Roy
gemdozer
Guest
PostPosted: Wed Jul 04, 2012 3:17 pm    Post subject: Re: AC HD 10 steering brake problem Reply to specific post Reply with quote
I should have a good used brake and band set for HD11 they should be the same than the HD10
lemmond1
Guest
PostPosted: Thu Jul 05, 2012 5:03 am    Post subject: Re: AC HD 10 steering brake problem Reply to specific post Reply with quote
What do you want for the brake shoes? Roy
