TO 35 breather tube
Steve K
PostPosted: Wed Sep 12, 2012 1:44 pm    Post subject: TO 35 breather tube Reply to specific post Reply with quote
Does anyone know where to find a replacement breather tube for a 1959 To 35 gas engine? Mine has almost rusted off completly. Not sure if I could just fabricate a tube or if there is supposed to be a check valve of some sort in the tube or at the rocker cover. Thanks for the help.
s19438
PostPosted: Wed Sep 12, 2012 2:21 pm    Post subject: Re: TO 35 breather tube Reply to specific post Reply with quote
walts tractor parts. $14.97
to30to35mf35
Guest
PostPosted: Wed Sep 12, 2012 2:51 pm    Post subject: Re: TO 35 breather tube Reply to specific post Reply with quote
take the tube to a ex/muffler shop thay can bend you a pipe
Charles in Aus.
PostPosted: Wed Sep 12, 2012 11:43 pm    Post subject: Re: TO 35 breather tube Reply to specific post Reply with quote
FE 35 breather tubes are made of 1/2'' copper pipe , fairly easy to bend and solder.
Steve K
PostPosted: Thu Sep 13, 2012 8:51 am    Post subject: Re: TO 35 breather tube Reply to specific post Reply with quote
Thanks for the replies. I'll try to find Walts Tractor Parts.
Steve K
PostPosted: Thu Sep 13, 2012 12:26 pm    Post subject: Re: TO 35 breather tube Reply to specific post Reply with quote
Walts no longer has them available. I guess I"ll have to fabricate one.
s19438
PostPosted: Thu Sep 13, 2012 1:20 pm    Post subject: Re: TO 35 breather tube Reply to specific post Reply with quote
rats.
did you tell them to take the item off their web site since they don't carry it.
Jerry/MT
PostPosted: Thu Sep 13, 2012 3:59 pm    Post subject: Re: TO 35 breather tube Reply to specific post Reply with quote
there is genrally a rstrictor orifice in the draft tube. Look at your old one and see if it"s there.
JPFL
Guest
PostPosted: Fri Sep 14, 2012 6:10 am    Post subject: Re: TO 35 breather tube Reply to specific post Reply with quote
Will a TO30 valve cover(Z129) interchange??? I have 2 of those. Jim --No-Advertising-in-Forums
Steve K
PostPosted: Fri Sep 14, 2012 8:40 am    Post subject: Re: TO 35 breather tube Reply to specific post Reply with quote
Thanks Jerry, the tube is missing, broke off, right at the bend where it turns down. Not sure if the restictor was in that portion or at the valve cover.
Steve K
PostPosted: Fri Sep 14, 2012 8:44 am    Post subject: Re: TO 35 breather tube Reply to specific post Reply with quote
Thanks jim, I'm not sure if they are the same. I should pull the cover off one of these days and adjust a noisy rocker. Would be a good time to replace cover. I'll do a bit of reserch or perhaps someone else might know if the covers are interchangable.
